lamda overlay not showing up
efdc5
Post by efdc5 »
Hi guys im new to kpro, just recently got it and installed. I have the car up and running but im not seeing the lamda overlay. Nothing is populating at all. Currently im using the base map 05 rsx in closed loop to get it running. Im running the latest software version 4.4.4. on the display tab i can see my af sensor working fine. I have a lot of experience with tuner but very new to kpro. Help would be nice thanks.
My setup/car
2005 rsx type s.
kpro for 05 with jumper harness with 04 rsx af sensor
turbo
id 1000 injectors
fuel return
Re: lamda overlay not showing up
Post your calibration as well as a datalog showing the issue.
efdc5
Post by efdc5 »
I will when i get home from work. Even loading other people's map and data log nothing shows up on the lamda overlay. I downloaded a couple of maps and logs here in the forum.
efdc5
Post by efdc5 »
Here is the base calibration i made to get the car running. Dont have any datalog yet. i will work on that
efdc5
Post by efdc5 »
Just wanted to update. I fixed the problem by going to options, settings, sensor overlay then unchecked calculate for each cam angle. Been busy building k24/k20 for boost. Hope this will help someone out
