First Datalog after AEM wideband PRA ecu [EP3]
jdouille
Post by jdouille »
Hey Hondata team's
Following my intermittents performance problems, before and after mapping.
I installed an AEM 30.0300 wideband on analogic plugs for totaly delete OEM narrowband. Here are the results with the AEM.
What do you think because I always have an irritating and unstable car.
Hondata Kpro V4 by CPL RACING
Kmanager 4.4.4
Map 240ch & 230nm
Mapping AEM wideband PRA ecu.kal
WOT 4th.kdl
Cruising.kdl
Cruising & WOT.kdl
Crancking.kdl
Thanks !!!!!
Re: First Datalog after AEM wideband PRA ecu [EP3]
Have you discussed these tuning issues with CPL Racing?
jdouille
Post by jdouille »
CPL RACING have tested my ECU with other car and tune without any problems. Perfect ecu and Kpro card. I made two maps a year apart with
similar performance, 240ch and 230nm on Dyno. But on the road it's stange comportement.
For what ? have you see an problems on Datalog ?
thanks.
If the issue is intermittent, it could be a wiring related issue, or it could be a tuning issue. You should discuss this with your tuner.
jdouille
Post by jdouille »
Okey, but have you see any problems on Datalog ?
jdouille
Post by jdouille »
Because on WOT 4th it's very slow and rich, Lambda is very high compare to my target at 13.2 I 'm not an expert but i's possible any leaking, intake manifold or bad fuel pressure or electrical problems..... ????
Lambda in 4th at WOT look ok. Lambda cruising looks ok. Where exactly are you experiencing the poor running?
jdouille
Post by jdouille »
Hi.
On Datalog WOT 4th, 5100rpm as pic at 11.51 afr, it's very rich for natural aspirated and stock internal K20.
See at 22s and 1.10m
And the afr its not linear,clean, he is very cahotics.....
thanks
WOT 4th.kdl
That's from VTEC.
jdouille
Post by jdouille »
Hi.
On my map, VTEC kick at 4200rpm not 5100rpm and normaly the target lambda curve on my map it's high 13.6 or 13.2 AFR curve and on Datalog i see
between 12.5, 12.8 AFR régular and pic at 11.46 it's more rich...
I do not understand that the target is at 13.2 and that I can read more than 12.5 it's little differents.
K20a2 EUDM Sp98 fuel
Flowstack, CAI, intake manifol, exaust, Deatschwerks dw65c, RDX injecteurs and KproV4
N/A 240ch
jdouille
Post by jdouille »
jdouille wrote: Fri Oct 16, 2020 5:57 am Hi.
On my map, VTEC kick at 4200rpm not 5100rpm and normaly the target lambda curve it's 13.2 AFR curve and on Datalog i see
between 12.5, 12.8 AFR régulary and pic at 11.46 it's more rich...
N/A 240ch
jdouille
Post by jdouille »
I have a " WOT compensation fixed at lambda 0.85 (12.5:1) " enable in Closed loop advanced it's normal ?
