P1162 error code hondata krpo V3 Aem wideband 30-0300
K20sleeper
Post by K20sleeper »
Hi im having a problem with my k20a dc5. My ecu is prb hondata k pro v3 serial number 12612. I using a aem wideband 30-0300.. A error keeps popping p1162 air and fuel ratio slow response.. I did check all the wires everything is installed properly..
Re: P1162 error code hondata krpo V3 Aem wideband 30-0300
This could be a problem with the wideband sensor itself.
the_jaykobe
Post by the_jaykobe »
I'm using a v3 Kpro prb, with a 0300 aem Wideband. I have zero issues, and it's functioning perfectly fine. Did you hook up both posi/neg wires into the analog input on the Kpro?
