No active display readings
TechAngel
Post by TechAngel »
I just recently got a basemap for my car. ive got a hondata s300V3 socketed inside of what i assume is a p28 ecu. everything functions normally as it should. Im able to edit everything, i can set the rev limit to whatever i want, upload it, and itll bounce off of said rpm. When i go into the display portion of smanager, i load a preset and it pulls up. The rpm doesnt change, nor does anything else. Any help would be appreciated!
Re: No active display readings
What are you clicking on to begin datalogging? It does not show data just by pugging it in.
TechAngel
Post by TechAngel »
Sorry i'm an idiot. I figured that out after about an hour of messing with it. Thank you for the reply!
