sManager Crash downloading from ECU
skubasteeve
Post by skubasteeve »
I recently bought a Del Sol with Hondata S300 v1 and I am trying to retrieve the map from the ECU.
I can datalog without any issue but if I attempt to download from the ECU... sManager crashes.
Re: sManager Crash downloading from ECU
Try closing all the windows in Smanager and see if it works. If it still does not, then you will not be able to use the calibration in the s300.
skubasteeve
Tried that, as well as reinstalling sManager. No dice.
Does this mean the only way I can do it is to create a new calibration?
Is there somewhere to grab an older version of sManager?
IT appears that the calibration is corrupt and you will have to start with a new calibration.
