E85 cold start in new york
k24_chris
Post by k24_chris »
Hi just wondering how can I adjust my map to turn the car on cold start. It’s 30 degrees here in New York and my si is a built motor. K24a2 block 12.5 bc rods supertech springs and retainers and valves skunk2 ultra 4 cams. Full ported Xsseive side feed ktuned 72mm 4” cai id 1000cc injectors. Walbro 255 on e85.
Re: E85 cold start in new york
Have you discussed this with your tuner?
You may have to reduce the amount of ethanol in cold weather.
k24_chris
Post by k24_chris »
I tried calling my tuner but no answer. How can I reduce the amount of ethanol?
put less ethanol in the tank
Look at the Calibration -> Ethanol -> Ethanol ECT cranking table and either post the calibration or tell us what is in it.
k24_chris
Post by k24_chris »
i think i figured it out. in the cranking fuel trim table, the 1st column from 0 rpm - 2000 rpm i raised it by 15% and the car started.
