Not starting after map sensor change
Johnr051
Post by Johnr051 »
I recently did finished my boosting my a3 and it turned on fine but I was missing a 4bar map and a crank pulse plate, after I installed both the car cranks but doesn’t turn on, it’s receiving fuel and spark and no errors are popping up on ecu
Re: Not starting after map sensor change
Have you set up the calibration properly for the Map sensor you are using and uploaded to the ECU?
Johnr051
Post by Johnr051 »
Yeah I received a base map from my tuner
but has it been setup correctly for the MAP sensor you are using in the parameters section.
Johnr051
Post by Johnr051 »
Yes I have a base map from Jamie marsh, and he has all the specs for my swap
Post your calibration and well as a datalog showing it trying to start.
