Custom Wideband (Spartan 14point7) on analog0
zeba5
Post by zeba5 »
Hello, i wanted to ask for a little help here. Ive bought a wideband controller from 14point7 called Spartan pro. It has a Linear Output: 0[V] @ 0.68[Lambda] linear to 5[V] @ 1.36[Lambda], 10[AFR] linear to 20[AFR] equivalent for gasoline
Thing is, if i set those custom values i cannot use it for the closed loop. Anyone knows which of the predefined wideband sensors is the most accurate for that reading? I just hope that one of them has the same reading.
Thanks!
Re: Custom Wideband (Spartan 14point7) on analog0
You cannot used custom setups for closed loop. Only the redefined Widebands will work.
zeba5
Post by zeba5 »
Spunkster wrote: Fri Nov 06, 2020 5:17 pm You cannot used custom setups of closed loop. Only the redefined Widebands will work.
Yes, i'm aware of that. That's why i'm asking if one of the predefined WIdebands have the same linear output as the one that i have.
zeba5
Post by zeba5 »
to answer my own question it appears that PLX SM-AFR has the same linear scale as Spartan.
https://www.plxdevices.com/v/vspfiles/s ... _guide.pdf
