SManager application keeps closing
g0sammo
Post by g0sammo »
I am having a problem with the Smanager application. I can open the program and everything seems normal but the application will just close by itself with no warnings after a minute or two. I have added the application to my antivirus software so it shouldnt be shutting anything off. I have tried shutting down all of the antivirus and still get the same results. Also downloaded application onto a different laptop and am still having the same issue. Please help i need to do some datalogging and make some changes to my tune!
Re: SManager application keeps closing
What is the anti-virus? Does your anti-virus flag SManager is any way? Are you using the same anti-virus on both laptops?
Have you tried uninstalling the antivirus software?
g0sammo
Post by g0sammo »
I am using webroot antivirus software. It flagged when i originally downloaded the software but i added it to the allowed applications and havent had a problem as ive been using it for quite a while. Yes both laptops use the same antivirus software. I will try uninstalling the software completely to see if that will allow it to run without closing and report back
g0sammo
Post by g0sammo »
Uninstalled antivirus software and application runs fine. It must have been running even with everything shut off. I reinstalled and now it is not causing any problems so the issue is resolved. Thank you for your help!
