Civic 1.5T China 2020 MT After flashing engine cant start Cruise control dont work
Civic 2016+ 1.5 Turbo
ssh
Post by ssh »
ECU:37805-5AF-BH10
Before flashing,the Cruise control can work.
After flashing the Hondata program, The engine cannot be started.(The starting motor keeps ringing)
If flashing back to the original factory program the engine can work again,but the Cruise control dont work.
there is two questions ask for help:
1.How to flashing the Hondata program without engine problem.
2.How to get the Cruise control back.
Thanks!
Re: Civic 1.5T China 2020 MT After flashing engine cant start Cruise control dont work
Please use the 'send feedback to Hondata' menu option.
ssh
Post by ssh »
Thank you. It has been sent with feedback.
janemar
Post by janemar »
Had the same issue.
Already sent feedback to Hondata.
Thanks!
Please use the latest beta version
janemar
Post by janemar »
Fixed it using this new version. Thanks!
ssh
Post by ssh »
Thanks you!
The engine starting problem has been solved!
But the Cruise control still doesn't work.
When I bought the car, I customized the cruise control at the dealer.
Now,Press the "Cruise" button can light up cruise control sign but "set" and "res" button doesn't work.
The dealer said it couldn't be solved if i want to use hondata program.
So I can only ask Hondata for help now.
If you return to stock does the cruise control work?
What exactly does that mean?
ssh
Post by ssh »
Hondata wrote: Fri Nov 27, 2020 8:59 am If you return to stock does the cruise control work?
Return to stock the cruise control also doesnt work.
The dealer added the cruise button module to my car and change some code in ECU program to make the button work.
So after flashing hondata, the cruise control doesn't work.
The dealer said only reflash their ECU program can let the c.c work again,that means hondata will be covered.
ssh
Post by ssh »
here is the program from the dealer
Sorry but there's no way for FlashPro to know what ECU binary to use if it is not stock to begin with.
ssh
Post by ssh »
Thanks,i will try to find another way.
We can add the cruise control switch to a future software release.
ssh
Post by ssh »
Hondata wrote: Tue Dec 01, 2020 4:18 pm We can add the cruise control switch to a future software release.
It's really good news.
xiplus
Post by xiplus »
ssh wrote: Wed Dec 02, 2020 2:56 am
解决了吗
