Flashpro says ignition not on
Rowzswagga
Post by Rowzswagga »
So I was having problems with the flashpro not reading the ecu. Now that I got that out of the way, I tried locking the flashpro to the ecu. It says flashpro is connected to the ecu but when locking the flashpro turn the ignition on. The ignition is on but it says its still off. Does anyone have a solution to this problem?
Rowzswagga
Re: Flashpro says ignition not on
Rowzswagga wrote: Fri Nov 20, 2020 8:28 pm So I was having problems with the FP not reading the ecu. Now that I got that out of the way, I tried locking it to the ecu. It says flashpro is connected to the ecu but when trying to lock the FP to it, it has a error message saying turn the ignition on to lock the ecu to FP. The ignition is on but it says its still off. Does anyone have a solution to this problem? I also downloaded the new version that just came out. Still same result.
Try the FlashPro in a different vehicle to see if it can detect the ECU and ignition being turned on.
Rowzswagga
Ok im gonna try that. Thank you🙏🏽
