hey guys i just picked up a s300 in a p75 i need a basemap made please
auto to manual conversion
2001 b18b1 stock longblock
gsr? lsd trans no identifiers other than ysk
skunk2 proseries gasket, manifold 70mm throttle body
schedule 40 ram manifold
rev9 tx-66-62 antisurge t3 turbo
3" exhaust
bk7re ngk spark plugs gapped to .020
tial 40mm mvr running 7psi spring
huntertuned decapped e85 injectors 1000cc(realistically flow at 920cc)
aem 340lph fuel pump
currently on pump gas but with switch to e85 once i get it running and build/clutch broken in
offbrand 4bar map no scalar but ordering a new one so stock for now\
aem uego wideband
b18b1 turbo basemap needed 7psi@1000cc@340lph
Projekt2nr
- CalibratEd
- Contact:
Re: b18b1 turbo basemap needed 7psi@1000cc@340lph
I can help if you can provide datalog with a wideband input. Do you need a basemap because you plan to get the car tuned? What is your goal?
-Ed
-Ed
Instagram: calibrated.tuning
Projekt2nr
yeah i need a basemap
If you still need a map made, shoot me a dm over and I can get you one made throughout the day. I’m running an almost identical setup in my own
Rickysb18turbo
Yo could u send it to me to also what numbers do you think you’re making ?
have 1000cc injectors and stock fuel pump is that ok or do I need a bigger fuel pump my goal is 300-350wheel max ?
I also need a tune eBay turbo set up and stock b18b any maps yall could send me thanks
I never saw these replies, Are you able to DM me? I'll get you a map made for your setup
