Aem digital boost gauge install
Projekt2nr
Post by Projekt2nr »
I wired up my digital boost and uego wideband to the same wires rywire tapped the uego wideband on my obd2b jumper and kept blowing my fi e/m 15a fuse. I’ve since decide to just wire the uego to d10 can I leave the digital boost gauge on d14? Or should I wire the digital boost away from the ecu? Thanks
Re: Aem digital boost gauge install
What are you trying to send to the ECU with the boost gauge?
Projekt2nr
Spunkster wrote: Mon Nov 30, 2020 10:50 am What are you trying to send to the ECU with the boost gauge?
i was hoping to just get the boost readouts matching as s300 reads. should i use the blue wire to an analog input or dont and just not connect it to the ecu
Draw a diagram of exactly how you have this wired please.
Projekt2nr
ill take a picture tonight homie
