Flashpro Manager 3.6.8.0 prolly some bugs?
itsmedvv
Post by itsmedvv »
Hello , this is DV, I am Software engineer and tuner and I wanted to share some probably issues in this version
After I have updated to this version I have detected in 8 gen civic turbo some issues with ignition timing
it looks like after VTEC, ingnition timing changed automatically to 60 degree causing damage in the engine :(
please see the image below
http://prntscr.com/vsn2zx
also another issue launch, before the issue with ignition timing i have changed in the steering wheel the RPM to the launch control but i was not able to rev upper that the calibration was set
Re: Flashpro Manager 3.6.8.0 prolly some bugs?
Can you provide the calibration and a datalog?
The 8th gen code has not changed for some years, but we can look at this.
itsmedvv
Post by itsmedvv »
I was doing some changes in fuel high, so we needed to do some pulls, i have detected that a couple minutes ago FlashproManager was closing for no reason and i had to reopen it 3-4 times FYI
I hope it can help to find the issue
Thanks a lot!
itsmedvv
Post by itsmedvv »
Here is another Datalog a couple minutes before the issue I had yesterday
Please disable live tuning and re-test.
