smanager not driver not installer
josean
Post by josean »
with my old pc I have no problem but with the new I open the programs and I get the driver not installer message under the program again and nothing under the drivers and nothing happens
Re: smanager not driver not installer
josean
Post by josean »
hondata Smanager 2.7.5.0
panasdonic fz-55 window 10 pro
josean
Post by josean »
Try restarting the laptop and then see if it will connect when the s300 is plugged in.
Also make sure that the ECU is plugged in to the vehicle and the ignition is in the on position.
josean
Post by josean »
try but nothing change
In Smanager, click on Help, then update USB drivers.
josean
Post by josean »
try it but it comes out you can't update the drivers
If it works on one laptop, but not another, then there may be a problem with the installation of windows. Make sure you are logged into the laptop as an administrator.
