Vss wiring help!
thatpinkescort
Vss wiring help!
Post by thatpinkescort »
I cannot find information that doesn't contradict itself. Trying to get an updated answer with V4 prb ecu
1994 ford escort gt
Jdm k24a2
2004 honda accord 5 speed transmission
2005 civic si engine harness
Hondata kprov4 PRB ecu
Hybrid racing universal harness
Can anyone explain how I need to wire my vss to read correctly in the hondata so I can set up boost by gear? I don't need anything with my dash to work...
Do I need to just repin connector and change a setting in kpro v4? Or do I need to find a 5v sensor output from ecu like the tps and then repin the other 2 wires like an 02-04 connection?
Re: Vss wiring help!
You should just need to re-pin the connector and change the setting in the calibration.
thatpinkescort
I thought one of vss sensors had a 12v source and one was a 5v ref. I don't need to do anything with that?
No other changes should be needed.
