Maximum AirC% the MAF/IAT2 can read.
touge tom
Post by touge tom »
Look i understand that the MAF/IAT2 doesn't read the AirC%.
But what is the maximum AirC% given that the maximum mass air flow rate can read.
I hope I'm not making myself hard to understand? Sometime lost for words...
Or what is the maximum AIR FLOW MASS VS what is the maximum AIRC% Anyone has seen before maxing out the MAF/IAT2 at its peak voltage.
P.s ive heard on the grape vine you guys are testing another MAF/MAF HOUSING that can read higher scaling.
Re: Maximum AirC% the MAF/IAT2 can read.
Air charge is not limited by the AFM. But you are right, the AFM on the FK2/FK8 is far too small.
Re-scaling the AFM table is something that anyone can do and we don't necessarily need to be involved.
touge tom
Post by touge tom »
That great.... I thought the max grams per second vs the max voltage was a fixed figure, so per the max voltage the gram per second can go higher. Thanks.
