Understanding traction control PlD
Sayanythng
Post by Sayanythng »
Should this feature be enabled? What does it do l? I’m getting a lot of retard going on caused by the vsa system
Sayanythng
Re: Understanding traction control PlD
If I enable traction control use pid and leave the values where they are what am I achieving?
First try changing the target slip until you find what works for you. Typical values are 2% - 6%.
If you're still getting a lot of slip in lower gears then next I would reduce the torque in 1st & 2nd gears.
Finally if everything is good then the PID can be altered to give a smoother retard. eg so it does not oscillate.
gotslicks
Post by gotslicks »
Question on tbe Pid settings. The default is 100 for p and d. In tbe help section it talks about settings of 1. Has something changed and should I start from 100 during testing?
Where in the help file exactly?
FK8_Hoonigan
Post by FK8_Hoonigan »
sorry for bringing this back, but this thread comes up often
under traction Control PID on Flashpro Manager....
What does "dec" mean next to the boxes? And what are the valid values to be used? 0-100? 0-1000? any integer?
Nothing in help files clarifies this
GARIX Tuning
2021 R-39464
https://dot.cards/garix
'decimal'. PID numbers are unitless.
Rares
Post by Rares »
Hondata I think Gotslicks was referring to this helper https://hondata.com/help/tractioncontro ... ontrol.htm
Does anyone have a log with traction control working and PID activated?
From what I understand, we can use it as a PD controller. I have experience with PID controllers from coffee machines, so I will try to test how it improves the efficiency of the traction control.
