2013 civic si
backstrom1202
2013 civic si
Post by backstrom1202 »
Question for you is I’m boosted and was wondering does Hondata see boost. And if so I’m running aem tru boost does that need to be wired up to the ecu to see boost
CalibratEd
Re: 2013 civic si
Post by CalibratEd »
backstrom1202 wrote: Sun Dec 27, 2020 6:44 pm Question for you is I’m boosted and was wondering does Hondata see boost. And if so I’m running aem tru boost does that need to be wired up to the ecu to see boost
Hondata reads the boost via the MAP sensor.
-Ed
Instagram: calibrated.tuning
backstrom1202
Re: 2013 civic si
So your does that mean I need to wire the boost controller or wideband to ecu
CalibratEd
Re: 2013 civic si
backstrom1202 wrote: Fri Jan 01, 2021 2:21 pm So your does that mean I need to wire the boost controller or wideband to ecu
The boost controller does not need to be connected to the ECU as the AEM Tru boost is a stand alone unit. I have read around that you can connect the AEM Tru Boost solenoid to the ECU so that you can control it via Hondata. You would have to look into that. If you have an external wideband you will have to connect it to the ECU.
-Ed
