TPS error
Johnr051
TPS error
Post by Johnr051 »
My tps is showing high voltage and min 40% when closed and 112% open is that okay to leave in the calibrations? And also my swap won’t stay on unless I give it gas it’s a 4bar map with 1000cc is it because of the tps or injector
danielthenerd
Re: TPS error
Post by danielthenerd »
If you loosen the bolts holding the TPS, you can adjust it to 0, or close to it, when closed. Also be sure you don't have the throttle cable too tight with cracked slightly.
Slow is smooth. Smooth is fast.
