d16a6 vitara 750cc 20psi
just picked up a crx with a 75mm fj/Vitara build, comp cam, springs retainers, .70ar turbo, rc750 injectors, mac solenoid @6.1%(15 psi spring on wastegate)18-20 psi total. car has a lot of crankcase pressure and am rebuilding the engine but can someone look at this tune and let me know if its ok to run the car? its the tune the car came with.
- CalibratEd
- Contact:
Re: d16a6 vitara 750cc 20psi
Visually there is overlap in the fuel table which is unusual. To better inform you on how the car is running you need to post a datalog of the car running this tune.
-Ed
-Ed
Instagram: calibrated.tuning
ive been trying to street tune using the percent adjustment feature. here is my current calibration and datalog
currently just running wastegate pressure at 14psi.
Someone let me know if the timing is to advanced in boost plz
