Need K24 Base Rsx Cal
ianramos12
Post by ianramos12 »
K24A
50 degree vtc
rsx oil pump
rbc intake manifold
rsx type s throttle body
NEED HELP loaded up map but car dies after 1 second not sure what the problem is..
Re: Need K24 Base Rsx Cal
Are you using the crank sensor from the K24?
sauve
Post by sauve »
Did you get a base map? I have about the same setup
