i ordered a basemap and it didnt go well so im hoping to have more luck here. im using the f20b turbo base map in hondata's calibrations with alittle changes here and there but seems good untill 4500-5000 rpm at 10psi of boost. the rpm will start bouncing and there really no power after that. just wondering if someone can put out there tune thats close to my setup so i can make sure everything is good before i put it on the dyno to fine tune it.
h22a closed deck
eagle rods
type s nippon pistons
balance shaft delete
crower stage 2 cams with bc springs
stock valves
stock intake with butterfly valves deleted
850cc injectors
400lph aem fuelpump
td05 18g turbo
4bar map sensor
2.5 exhaust
dragonfire dizzy with msd coil
nrg sparkplugs gapped to .30
aem wideband set on d14
h22a 10psi
- CalibratEd
- Contact:
Re: h22a 10psi
Post the tune and a datalog of the issue occurring so we may better help you.
-Ed
-Ed
Instagram: calibrated.tuning
