Low/high boost install help
goppe
Post by goppe »
Hi , I want to have a low/high boost settings for my turbo rsx.
I have looked into using E16 pin and it says gnd=off. Does it work if I take the wire from E16 pin to a switch and from there to ground. Because when I flip the switch it gets ground and changes the boost by gear table to high/low, just invert signal if I want the opposite direction on the switch ?
Re: Low/high boost install help
Inverting it will just change when it is activated from grounding to on, to ungrounding it will be on.
goppe
Post by goppe »
Okay am I understanding the correct method to make the function work otherwise?
yes
