b20 tune maps needed
Hawkinsdan47
Post by Hawkinsdan47 »
i need help on a base tune for my build!! ! its being built for boost nut way past the limit for a little while. the list will be included
b20z2 block
-bored to 84.5mm
-has nippon phk pistons with -4.00 domes, 30.00mm comp. height
-scat forged rods with arp conning rod bolts
-arp main studed and girdled from screaming eagle
-cosmetic head gasket
-arp head studs
-bc0021 stage 2 turbo cams
-bc0020s springs
-acl bearings
-ferrea 6000 valves
- stock injectors atm
need a turn so id be able to rune the car until i can afford to boosting components
DaX
Re: b20 tune maps needed
Post by DaX »
Have you looked in the Hondata Vault?
Hawkinsdan47
i am new to all of this hondata program. where is the hondata vault found??
In Smanager, click on the Window menu and then click on search vault.
Hawkinsdan47
I figured it out.. also signed into the vault.. I may have found a b18b tune with my cams.. so imma try it on my b20 and see what the afr says
