Map sensor vs mBar reading
Hondahouse
Post by Hondahouse »
Watching my datalogs, and no matter at what road speed it seems, with only about 25-30% throttle I’m getting about 800 mBar MAP sensor readings and easily going WOT.
Any ideas? Bad sensor or plugged exhaust maybe?
2006 FG2, DC Sports SRI, TAYLOR Helix Throttle body spacer
Re: Map sensor vs mBar reading
Post your calibration as well as a datalog showing what you are describing.
Hondahouse
ok, attached is the calibration file and a datalog.
im hitting 900mBar @ like 50% throttle.
if you look at the fuel maps the 800+ mBar curves seem really high on some cam angles, compared to the lesser....
Also, what is with the symmetrical dips in the fuel curves within the same cam angle maps??
Thanks for the help.
The MAP / TPS relationship is normal.
Hondahouse
so a 900mBar reading at 50% throttle is normal @ 18:06 on the datalog (would be same as 100% throttle...), amongst the other 700mBar and higher readings at 20% throttle?
Also should the big dips in the fuel curves be smoothed out even though it goes against suggested lambda adjustments??
