I want to swap my K-Pro V4 PND ECU with a K-Pro PRD ECU installed by Hondata
snyderkj717
Post by snyderkj717 »
KPro SN: K-Pro4 52738
ECU PN: 37820-PND-A06
ECU SN: 2062-602504-0C25
Current K-Manager installed: 4.4.3
D17 AEM Timing Gear
I'm swapping a K24A + EP3 transmission (4.7 FD low-freq VSS) with Z3 6-speed gearset, Z3 4.7 final drive + LSD.
I want VSS, and reverse lockout to work on my '05 Civic.
I purchased my K-Pro D17 from HAMotorsports.
What are my options?
Privately sell my current K-Pro, and buy a PRD ECU. Then, buy a new K-Pro V4 from Hondata?
Re: I want to swap my K-Pro V4 PND ECU with a K-Pro PRD ECU installed by Hondata
If a PRB calibration is used and a PND ECU then you can use the secondary runner control to operate the reverse lockout by wiring the reverse lockout to that output.
