AC Switch
Tonyl
AC Switch
Post by Tonyl »
I'm currently doing a k20a2 swap in to my mr2 spyder, The instructions i have say that i use the vtech pressure switch (Honda ECU (B9)) reused to be the ac switch.
I've been through the provided K-pro setup 4-5 times, everything looks right and the ac still doesn't work/
If all of the settings are correct and as i understand it it's ground to activate, If i ground pin B9 should the revs of the engine increase ?
Re: AC Switch
What ECU is being used?
Tonyl
Re: AC Switch
Post by Tonyl »
37820-PRA-E12
Re: AC Switch
Is the AC system properly charged?
Tonyl
Re: AC Switch
Post by Tonyl »
Yes, It was working perfect before the swap a week ago.
Tonyl
Re: AC Switch
Post by Tonyl »
As part of the swap i also have to use a muliplexer to convert from toyota to honda, so at the moment i'm just trying to fault find.
If i earth pin B9 should the revs go up ? I'm starting to think the multiplexer might not be switching to earth.
