Honda Accord CL7 EuroR
AmarFirdaus
Post by AmarFirdaus »
Hi Hondata Bros,
I have problem with my car. I can crank, however the engine cannot start and the IMMO symbol are blinking.
I got this problem after I install my Apexi RSM meter.
Is that okay if I disable the IMMO?
Is the MAP will be safe?
Please advise.
Thanks.
Amar.
Re: Honda Accord CL7 EuroR
This vehicle is not supported with the K-Pro.
livinlow345
Post by livinlow345 »
To use the kpro you have to get a custom jumper or a custom harness dual ecu your stock ecu and kpro plug in same time I have 2 Cl7 Euro R boosted there equipped with custom built tuck harness check evolwire.com or @privatespec IG he sort all your needs out Dre work 💥🔥
