Tune resetting
Heyk20
Tune resetting
Post by Heyk20 »
Does the Hondata s300 v3 clear its memory if the car battery has been out for a few days? I noticed that when I went to look at my ECU today, everything was seemingly reset to stock. I haven't had any problems in the past with my tune resetting, but I haven't ever had it disconnected from the battery for too long. Here are the things that I have done before I noticed the reset:
Removed R136 and R138
Wired wideband Signal wires from wideband to D10 and A26
Wired wideband sensor and wideband gauge ground to A26
Could this have caused the reset?
Heyk20
Re: Tune resetting
Post by Heyk20 »
I have an update.
When I went to load my tune, I hit "Download from ECU". Is this not the proper way to get the calibration from my ECU? Should I always load the tune from my laptop? Could this be the reason that my tune is "reset"?
Re: Tune resetting
S300 window, Calibration Storage tab, Retrieve Calibration button.
The Online -> Download menu should do that same thing but this way I can be sure you're not downloading from the ECU memory.
Heyk20
Re: Tune resetting
Post by Heyk20 »
I have since uploaded a new calibration to the ECU. I will leave my battery out for the next few days and see if I can pull the calibration using the way you suggested. I'll report back here on what happens.
