knock
FlashPro questions & answers specific to the FD2 Japanese Civic Type R
aryeff112349
knock
Post by aryeff112349 »
Hi sir,
please kindly assist me regarding this knock.
i convert my car civic fd2 using ecu fd2 type R
engine civic fn2R
wiring civic fd2 type R
intake fn2r (RSP)
exhaust fd2 type r
All stock condition
i keep wandering this knock count is normal or not.
it only register knock on cylinder 2 and cylinder 3
kindly please advice me regarding this knock count.
currenly i using factory calibration
aryeff112349
Re: knock
aryeff112349 wrote: Tue Feb 23, 2021 10:06 pm Hi sir,
engine civic fn2R
intake fn2r (RSP)
exhaust fd2 type r
All stock condition
i try load reflash calibration. But total knock count on this two cylinder register more than factory calibration.
When i open datalog it show kock retard every time knock register.
kindly please advice me this real knock or mechanical noise. should i adjust ignition
Re: knock
Reduce the ignition timing 2 degrees on the high cam and if the knock control doesn't go up at 6300 rpm then it is knock.
But I think it is mechanical noise like the exhaust vibrating at that rpm, since the overall ignition timing is low.
aryeff112349
Re: knock
Thank you sir. I will try to reduce ignition timing.
