Base Map Modifications Throttle
Civic 2016+ 1.5 Turbo
yongfeel
Post by yongfeel »
Hey,
for 3.7.2, on the basemap mod, Throttle for MT sticks and will not disable. I have a CVT and would like to select only the throttle option for CVT but cannot get rid of MT. Is there any fix to this?
Thanks in advance.
janemar
Re: Base Map Modifications Throttle
Post by janemar »
CVT and MT cars have separate throttle tables.
Basically, even though you turned ON improved response for MT on your CVT car, it is useless since it doesnt use this table.
yongfeel
Post by yongfeel »
Janemar, thanks for your response. The issue is I never encountered a problem in Flashpro where I was unable to check/uncheck something in the modifications page. The checkmark for MT Throttle remains checked no matter how many times I click on it to disable it.
It is normal, do not worry about it. The CVT ECU has MT throttle tables which are not used.
yongfeel
Post by yongfeel »
Thanks Hondata team for reassurance. Either way, the problem is no longer prevalent in 3.7.3.
Sleeper_FK7
Post by Sleeper_FK7 »
How does the Throttle Stages work? I see in v.3.7.3.0 there is now three stages for throttle response. And two for throttle sensitivity? Which am I supposed to use if I used to use Improved Throttle Response?? I can't find any info even in the patch notes.
