FlashPro Manager 3.7.2.0 Out of date
Accord2008
Post by Accord2008 »
I cannot get FlashPro to work anymore. Tried first 3.6.8.0 with no luck, finally installed the 3.7.2.0 (beta).
All the time the "Out of date" message. Even tried to connect the FlashPro Module, which results in a Firmware Upgrade, but the program won't still work?
Re: FlashPro Manager 3.7.2.0 Out of date
Close FlashProManager, using regedit find \HKEY_CURRENT_USER\Software\Hondata\FlashProManager\FlashPro and delete the license key.
Start FlashProManager and then it should re-license by itself.
Accord2008
Followed the instruction but didn't help.
Check system clock is correct. Clear DNS cache (cmd prompt, 'ipconfig /flushdns')
Accord2008
Just tested. System Clock is correct. Flushdns didn't help either.
The About Box says "Exp Date: Sat. Dec 30, 1899"!?
Does SManager and KManager work ok?
Accord2008
I had installed KManager 4.4.2 which worked fine.
Just tried to install the newest Beta of KManager, 4.4.4 and it works, too.
No use for SManger, so i don't have it installed.
Only Flashpro Manager does not work.
Accord2008
Downloaded Version 3.7.3.0, now it works.
