S300 v3 no datalog and 4000rpm rev limit
nos-eg6
Post by nos-eg6 »
Hello guys.
I experience a problem with one of my s300 boards.
Serial number = 46200
Software version =2.7.5
Firmware =10
Calibration is for test a new p30 usdm file uploaded after i erased .
Vehicle is edm civic eg6 sir with the stock b16.
Using two ecu a p28 and a P30 both with new replaced capacitors in perfect working condition with other s300 v3 board.
The problem is that the ecu is not comunicate with s300 board which result to no datalog and 4000rpm rev limit.
When turn the key on the D3 led on the s300 stay on for a second and then shut off.
If ecu has communication with s300 board D3 led should stay on all the time.
Thats how an other s300 v3 board i have is working.
The problem is not from the socketing as did all the necessary tests for continuity with multimeter.
I have an other s300 v3 board with serial number 50201 which i tried and it worked perfect at the same ecu.
I also tried the faulty s300 board on the other known good ecu with same results.
Tested both on car and on engine simulator with same results
I believe that it is a firmware issue or the U1 chip .
Is there any way to reset or update the firmware ?
Does anyone know if this malfunction caused by any faulty component on the s300 board ?
nos-eg6
Re: S300 v3 no datalog and 4000rpm rev limit
Post by nos-eg6 »
Is J12 cut on the ECU?
nos-eg6
Post by nos-eg6 »
Yes of course J12 is cut.
I tested the faulty s300 board on an other ecu P30 which i am using a known good s300 v3 board and it does not work also.
I tested also the known good s300 v3 board on the other ecu and it works fine as it should.
Ecu with new capacitors.
The faulty s300 board shown online at the software with the above screenshot i posted.
On board dataloging is off.
I used a new P30 calibration uploaded fine to avoid the corrupted file calibration scenario.
S300 board is sitting properly at the pins and tested the continuity for every pin with multimeter.
So after these tests i made the conclusion that it is a firmware issue as the rev limit is restricted at 4000rpm and no datalog.
Could this be a hardware component failure on the s300 board ?
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
include a link to this thread
nos-eg6
Post by nos-eg6 »
Ok i send the mail to support and waiting for further instructions.
An other video showing the problem.
https://youtu.be/sT5ZcRyoVl0
nos-eg6
Post by nos-eg6 »
Just for reference for future readers of this thread the problem was a faulty s300 board.
Managed to deal a replacement with hondata.
