FK8 Datalog Sensors Showing No Data Flash Pro
LKCorbz
Post by LKCorbz »
Hello Apologies if this obvious, I am new to Hondata Flash Pro.
While using the Hondata Flash Pro I am not getting readings on a vast amount of sensors.
This includes Boost Pressure and Oil Pressure with what I believe to also be low fuel duty then expected (0-1% with the odd blip to 7%)
Also negative Knock Retard on Cylinders 2 and 4 of 85% and 75% respectively
I am running a stock FK8 with jailbroken ECU, no Calibrations have been uploaded to the car and BP does show on the drivers display, no error codes or warning lights.
FP-CTR-FK8-INT
FlashPro Manager 3.7.2.0
Datalog of a generic drive
UK/Europe FK8 Stock
Any Help is Greatly Appreciated
Re: FK8 Datalog Sensors Showing No Data Flash Pro
It is because you have not uploaded to the ECU.
If you want to datalog how the stock ECU drives then upload the 'factory settings'.
LKCorbz
Post by LKCorbz »
Thankyou
