Vtec not working when launch control is enabled
Blackoutthd
Post by Blackoutthd »
Vtec only works when launch control is disabled and it dose not work when launch control is enabled
P28 s300 obd1 1995 honda eg
I need 2 step for drag strip please help
Re: Vtec not working when launch control is enabled
Set the minimum speed to 0
Blackoutthd
Set launch control or vtec to minimum 0 mph
What input are you using for launch control activation?
Blackoutthd
I think it's just on mph but I do have my clutch safety switch looped you think that could cause an issue?
If you have it set to always on, then my question is not relevant.
Blackoutthd
I'll have to check when I get home but I dont have to hit any buttons my tuner set it up
Blackoutthd
It is set to always on and it's on mph I just want launch control and vtec
Post your calibration as well as a datalog showing the issue.
Blackoutthd
I'll do some datalogging tomorrow it's raining thanks I'm just trying to figure it out I'm so puzzled
Blackoutthd
I snapped my axcle but once I get my new ones I'll do some data logging I'm still trying to data log for you I tried to put it on brake switch but that didnt work either unfortunately
