S300 PLX Wiring Tech Page - 404 Not Found Error
midlana_steve
Post by midlana_steve »
Hey guys,
Wanting to install a PLX Wideband. Working through the forum and gathering all the information.
It looks like a Tech Page was put together about this (https://www.hondata.com/techplxwiring.html) but clicking on that link gives a 404 Not Found error.
Does anyone have the right link?
Re: S300 PLX Wiring Tech Page - 404 Not Found Error
Sorry, that page was out of date I believe.
If you are wanting to run closed loop from a wideband you must input the wideband signal directly into the ECU on an input such as D10. IT canto run closed loop form the analog or digital input on the s300 itself.
Info can be found in the help file: http://www.hondata.com/help/smanager/wi ... b=wideband
