K20Z3 Base Map Needed For Swap
9klifestyle
I'm swapping a k20z3 engine and trans into my EK civic and need a base map. The engine is stock internally. I have installed a k20a2 throttle body, with a header and 3 inch exhaust. I searched first and didn't see another thread with a response, so I'm hoping for better luck here. I'm using a KPro V4. Thanks!
- CalibratEd
- Contact:
Re: K20Z3 Base Map Needed For Swap
Start with a K20 stock file and dial it in. I can help if you can provide datalogs with wideband input.
- Ed
- Ed
Instagram: calibrated.tuning
