Gear Ratios
jmclaren
Gear Ratios
Post by jmclaren »
Hi,
First post here - I've searched but can't seem to find the answer.
I'm going to be running a digital dash/cluster soon, and my gear ratios don't match the calibration so it's going to show an incorrect gear position. Obviously this has never been an issue on a normal cluster
My question is - will changing the gear ratios in KManager automatically compensate fuel/ignition tables? I just don't want it to affect the tune in any way, just need the gear position to read correctly
Re: Gear Ratios
Changing the gear ratios will not change the fuel/ignition, apart from any gear based compensation tables.
