FlashProManager 3.7.4
V3.7.3 (11 Mar 2021)
  • Firmware updated to version 194
  • [2016+ Turbo Civic] Added support for Europe 2020 model 5AN-EC2, Canada 2020 model 5AF-CJ1 and 2020 model 5AF-C41.
  • [2016+ Turbo Civic] Added factory waste gate disable modification.
  • [2016+ Turbo Civic] Added quick modifications for throttle response, throttle sensitivity and intake selection.
  • 2017+ Civic Si] Added quick modifications for throttle response, throttle sensitivity and intake selection.
  • [S2000] Added secondary O2 sensor heater disable and P2270/P2271 disable.
  • [2020 FK8 Civic Type R] Added quick modifications for intake selection.
V3.7.4 (17 Mar 2021)
  • [2020 Turbo Civic - Japan] Fixed no boost problem.
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
Download here
hdaoud
Re: FlashProManager 3.7.3
Post by hdaoud »
after I increased throttle sensitivity the engine has be revving up to 2000 randomly after I release the throttle completely at low speeds or at idle? is this some new thing I don't understand? does it have to do with the throttle sensitivity mod?
What vehicle are you referring to?
berk
Re: FlashProManager 3.7.4
Post by berk »
hdaoud wrote: Fri Mar 19, 2021 1:27 pm after I increased throttle sensitivity the engine has be revving up to 2000 randomly after I release the throttle completely at low speeds or at idle? is this some new thing I don't understand? does it have to do with the throttle sensitivity mod?
I've noticed this too with my 1.5T civic. I haven't played around with it too much, but any throttle response/sensitivity "stage" above stock results in a weird fluctuating rolling idle (only with cruise MAIN off). I first thought it was specific to my vehicle because it failed a flash right before and maybe got corrupted. I was just relieved to have it fixed by disabling the sensitivity mods that I haven't played around with every combination to see what factor is at fault though.
Attached is a datalog and calibration showing this behaviour.
janemar
Post by janemar »
I can confirm this on my car too. 1.5T CVT.
For all who havent updated yet. Please stay put as this version is bugged
Can you tell us what vehicle and what sensitivity setting you were using.
hdaoud
Post by hdaoud »
2018 si. It's worrisome and sometimes dangerous when i'm cruising on first.
Can you tell me the build number of the software?
hdaoud
Post by hdaoud »
3.7.4
hdaoud
Post by hdaoud »
Version 3.7.4.0 build 2017
