HELP! ECU asking for PIN#
T5honda
Post by T5honda »
When I try to connect my laptop to my ECU via Bluetooth I can see it pop up under devises but when I click and try to connect it asks for a PIN# that I don’t have...?
Is their any way to Reset the PIN??
I lost contact information for old owner and hope I’m not sh** out of luck because I have no clue who tuned it or how to find the code, Any help would be very much appreciated thanks in advance!
Re: HELP! ECU asking for PIN#
The PIN is entered in the S300 window of SManager if you connect to the S300 via USB. The PIN probably is 0000 or 1234.
Windows has a special trick with BT connections where you have to try (and fail) three or four times in a row before it realizes that you can't type in a PIN on the S300.
