New Mods in 3.7.3?
Civic 2016+ 1.5 Turbo
Noob240
New Mods in 3.7.3?
Post by Noob240 »
Just curious about a few new options. Or maybe someone could help me select the best options for power and reliability. Used to use +6psi cvt basemap but now I see there is High Output and 265kpa 93oct min. Could someone tell me the main differences? And now I see there is new throttle options. I used to just select Improved Throttle Response and now there is stages? Which is best for stock 2018 fk7 1.5t with cvt? I've heard good things about the Artificial Knock Disabled. Any other bonuses?
Noob240
Re: New Mods in 3.7.3?
Post by Noob240 »
I do now have a PRL CAI w/ race maf and PRL FMIC w/ CP. Seriously any help with the throttle stages would be greatly appreciated!
You can try the different stages and see which you like the best.
Sleeper_FK7
Post by Sleeper_FK7 »
Same with the throttle sensitivity options? Just confusing with stages now. That would lead me to believe you need different upgraded parts in order for them to run effectively like in order to use different stages on COBB you'd need aftermarket intake, intercooler, and exhaust. That's just not the case here?
No. They are just varying degrees of alteration.
