Wastegate Always Disabled
Civic 2016+ 1.5 Turbo
berk
Post by berk »
Hi all,
I was eager to test out the new throttle response settings in the latest update for the 1.5T civics, but it appears I have lost all boost regardless of mode.
Attached is my calibration and a short datalog exhibiting this behaviour. Each WOT I cycle through cruise MAIN, and ECO modes.
I have tried reverting to my previously known working calibration, but that too no longer functions correctly. I've also tried checking off "Disable wastegate" in case that option is inverted, but it has made no difference.
Is this simply a bug with the latest update? I can't foresee it being a mechanical issue as WG is always the same as WGCMD, but I'll happily be corrected or try new things to figure it out.
Thanks in advance.
Re: Wastegate Always Disabled
There is a bug in the software and it will be fixed shortly.
Please try this version
berk
Post by berk »
I've downloaded the linked version and it seems to have fixed the boost issue.
Thanks again for the quick fix, the sunny weekend awaits!
Thank you for the quick feedback.
Sleeper_FK7
Post by Sleeper_FK7 »
Is there any benefit to disabling the wastegate??
It is only there for people who swap in after market turbos which do not use the factory wastegate.
