Xdi pump enabled?
Mattztoyz
Xdi pump enabled?
Post by Mattztoyz »
Just installed a xdi pump into our 2017 type r, and was trying to enable the hpfp, and it says enabled but serial number and software keys are greyed out and I cant type anything in there?
Is that normal? And safe to start the car?
Or is there something I'm missing?
Thanks!
Re: Xdi pump enabled?
Did you enable the XDI pump mod in your calibration and upload to the ECU?
Mattztoyz
Post by Mattztoyz »
Yes, I enabled the xdi pump mod and uploaded it :)
Then it should work.
Mattztoyz
Post by Mattztoyz »
Perfect! Thank you so much! I just wanted to make sure before I went and did something I shouldnt be !
Bain
Post by Bain »
Hi,
Will this pump also work on the FK2 ?
No, it will not.
Bain
Post by Bain »
thanks, is there or will there be a option for the fk2 for fueling.?
There may be in the future.
