S2000 VTEC Pressure Switch
timg
Post by timg »
I've noticed that in a couple of < 2005 S2000 calibrations I've seen, the VTEC pressure switch enable box is not ticked. In the later 2006-2009 dual wired Pro it is ticked.
Questions:
is this correct that the 1999-2005 S2000 Pro has the VTEC sensor disabled by default?
Does this mean that the sensor can be deleted? I'm wondering about deleting mine to gain clearance for a larger turbo.
Tim
Re: S2000 VTEC Pressure Switch
It uses the VTP input as the input for the AC switch.
