Kpro4 injector dead times
jasonvawter
Post by jasonvawter »
Im inputing my injector dead times to my kpro4 prb ecu (f20c) and i have all the info in front of me. I noticed that my fic 775 cc injector paperwork gives the lowest voltage offset at 8 volts and the lowest in kpro is 6volt.
Is there a formula for calculating whaT the dead time would be @6volts? Or should i leave it blank (0.0)?
Thanks!
Re: Kpro4 injector dead times
Just input the voltages you have. You can modify the minimum voltage in the table.
jasonvawter
Thanks for that!
I called fic and they said that the injector likely would not see a voltage that low and that i could keep it at 0
Cheers!
