After install of PRL cold air intake
Civic 2016+ 1.5 Turbo
Dan123inc
Post by Dan123inc »
I recently installed a PRL race CAI in my honda civic. I have the CARB hondata flashpro and tuned the car to the +6 PSI base map. The day after I installed the CAI, I got the check engine light. After getting the code for the CEL, it stated I was running to lean. Do you all mind checking my logs to see if I am. Waiting for a non carb flashpro to be delivered and will switch over, just wanna see if my A/F ration is not that lean, and if I am still able to drive my car moderately while I wait for non-carb flashpro.
Re: After install of PRL cold air intake
Nope, you need to remove that intake if you can't tune for it. The trims are really lean.
