V.4 VSS output
goppe
V.4 VSS output
Post by goppe »
Hi , I saw in this video https://www.youtube.com/watch?v=A4-ECo9 ... TECAcademy
about CSS/VSS. I have a rsx 02 with a transmission that uses CSS.
I have a question does this work on all Kpro V.4 , Brian says in the video that it only works if hondata themselves have installed it ?
Re: V.4 VSS output
It will not work on K-Pros installed by dealers.
goppe
Re: V.4 VSS output
Post by goppe »
Okay thank you for answer , is there somehow to make it work ?
goppe
Re: V.4 VSS output
Post by goppe »
My kpro reads speed with the countershaft sensor connected, just need to get my cluster working properly.
Re: V.4 VSS output
You will need a speed converter for the dash to read correctly.
