FlashPro CARB 6psi base tune + Mishimoto SRI?
Civic 2016+ 1.5 Turbo
CypherBlaze1
Post by CypherBlaze1 »
I've got a 2017 Civic sport hatch (1.5T, CVT) and I just bought the FlashPro CARB, and I'm planning to use the +6 psi base tune. Currently my car is equipped with a Mishimoto short ram intake, which is CARB legal. Supposedly if it's CARB legal, then it doesn't require and running, and can be used with the FlashPro CARB base tunes. But yet I see in the FlashPro Manager that there is a non-CARB base tune for that specific intake.
I'm a noob at tuning and flashing so I'd like to get a definitive answer. Can I use my Mishimoto intake with the CARB +6psi tune? If I did, what would happen? Or do I need to return the intake to stock??
A second question is if I use the intake and the +6 tune, will that add too much power and be potentially unsafe for the CVT? From what I understand, the +6psi tune adds 25HP and 35FtLbs torque, and the Mishimoto intake supposedly adds 16HP and 20FtLbs torque. That brings the car up from 180HP, 162FtLbs, to 221HP, 217FtLbs
Any answers/advice would be greatly appreciated
Re: FlashPro CARB 6psi base tune + Mishimoto SRI?
As long as it's a CARB approved intake then it will not need any custom tuning to work properly with the CARB calibrations.
The calibrations we provide should be safe for the transmission as long as you do not power brake to launch.
CypherBlaze1
Thanks for the quick response. The reason I ask is because the non-CARB calibrations fur the car include one calibration for this intake. If this intake doesn't require any custom tuning, why is there a separate calibration there in the FlashPro Manager for using it?
It makes people feel better that the intake is listed. Don't worry about it.
CypherBlaze1
Haha ok thanks 👍
xSDMx
Post by xSDMx »
CypherBlaze1 wrote: Tue Mar 23, 2021 11:47 am I've got a 2017 Civic sport hatch (1.5T, CVT) and I just bought the FlashPro CARB, and I'm planning to use the +6 psi base tune. Currently my car is equipped with a Mishimoto short ram intake, which is CARB legal. Supposedly if it's CARB legal, then it doesn't require and running, and can be used with the FlashPro CARB base tunes. But yet I see in the FlashPro Manager that there is a non-CARB base tune for that specific intake.
Did you end up having any issues with getting your car smogged? Which intake and tune configuration did you settle on? I need to get my 2017 Civic smogged and I found out my Injen SRI never got a CARB EO.
CypherBlaze1
I've been usung my Mishimoto intake with the CARB compliant +6 PSI high octane tune, with no issues. With stage 2 throttle response, standard throttle sensitivity, and street launch traction control.
I live in Florida where it's not required to have routine emissions inspections, so I don't know if my car would pass the smog test, but since the intake and the tune are both CARB legal, I assume it would pass no problem. I'm not sure about your Injen intake though.
