Throttle response vs throttle sensitivity?
CypherBlaze1
Post by CypherBlaze1 »
Sorry if these are stupid questions but I'm a noob.
In the modifications window, what exactly is the difference between throttle response (standard, stage 1, stage 2) and throttle sensitivity? (Standard, stage 1, stage 2)
I tried Google but no luck.
Also in the same window, what's the difference between the Traction Control options "no wheel spin launch" and "street launch"? I understand no wheel spin launch, but what is street launch? Some wheel spin but limited? How are these different from the stock traction control, which to my knowledge is already supposed to prevent wheel spin?
Re: Throttle response vs throttle sensitivity?
They are just different levels of sensitivity. You can try them and see which you like best.
If you look at the notes for the mods it gives details on what the difference is. You can also try both settings and see which you like better.
fusionbuzz
Post by fusionbuzz »
Is enabling either of these combinations safe for a CVT (with no other software or hardware mods)?
1. Throttle response - stage 1 and throttle sensitivity - stage 1.
or
2. Throttle response - stage 1 and throttle sensitivity - stage 2.
Thanks!
Yes, they are both safe for the CVT.
powercarfixit
Post by powercarfixit »
What was the setting used by Hondata before the multiple choices for throttle?
torresp
Post by torresp »
Is this combination safe for a CVT (with no other software or hardware mods) too?
Throttle response - Stage 2 and Throttle sensitivity - stage 2.
